I have a 1979 Johnson 100hp outboard motor and I have no spark at the spark plugs. Before I begin changing the coils, power packs, rectifier or stator I was hoping to get some help from this forum, which I have heard great things about.
1. As I understand it, the stator produces the electricity to the power pack, which go to the coils and then to the spark plugs. How can I tell if my stator is functioning properly? Can I use a continuity tester to see that current is coming from the stator? If so, how would I do this? If a continuity tester cannot be use, what then would I use to complete the testing?
2. Assuming that the stator test comes out positive, how can I tell if my power packs are functioning properly? Can I use a continuity tester to see that current is coming from each of the power packs? If so, how would I do this? If a continuity tester cannot be use, what then would I use to complete the testing?
3. Assuming that the power pack test comes out positive, how can I tell if my ignition coils are functioning properly? Can I use a continuity tester to see that current is coming from each of the power packs? If so, how would I do this? If a continuity tester cannot be use, what then would I use to complete the testing?
Thanks in advance for your help.
