hello<br /> Im working on a johnson 60 horse 1970 (60ESL7OB) the ignition switch at the throttle needs repairing so i attached wires to all 6 locations on switch and this is what i have tried by conecting different arrays of these wires at the ignition switch positive hot to what i guess is ignition and i get spark on one plug once when wire touches then other plug when i turn flywheel and touch hot to ignition again, then 3ed plug. this i think must indicate that the possibility of spark is there if i figure out how to wire it. when i touch hot to starter wire it engages but no spark. i then figured that i need to connect hot to ignition (which causes an ongoing ticking or spark sound somewhere) then touch starter wire. the result is no spark on any of the plugs which are out and grounded while starter is turning engin over. my theory could be all wrong since i realy no very little about motors. thanks a lot in advance.
