newbie600rr
- Joined
- Jun 20, 2008
- 52
I have a 82 50hp johnson that I had a little problem with. I have 2 questions.
1. Would a low battery cause a no spark situation. I have been doing some work on my boat and have not had the motor running for about a month. Went to go start it yesterday and had no spark. Did a few test and didnt come up with an answer to my problem. Tried today and same problem. Put the charger on for a few minutes and it started right up. Tried it about 4-5 times thruout the day and no problems. Would a dead battery cause this.
2. I think my rectifier is bad. I did the test and only had movement on the meter while touching the black to ground and red to the three yellow wires. No other movement on the meter so I think it is bad. My question is will it hurt anything if I run it with a bad rectifier. It is suppost to charge the battery but with the bad rectifier will the motor pull a drain on the battery while it is running causing a dead battery. I really want to use it this weekend but dont want to cause more harm.
Thanks
Chris
Thanks
Chris
