No Spark (and yes I checked everything according to the check list)
udm328is
Ok, so I checked everything according to the check list and still no spark. I have a Mercruiser 5.0 with the Thunderbolt ignition and after going through everything on the check list I am still stuck, Any ideas? It seems I have a fuel issue as well as it seem nothing is sparying out when I pump the throttle, but I need to get someone to look when I do it to make sure but looks like it is still dry when I do, but I'll get more into that when I read up on that I guess unless there is any chance the two issues are related.
As always thanks in advance for any help and suggestions,
Eric
Don S
Re: No Spark (and yes I checked everything according to the check list)
What check list are you referring to?
Got a serial number for your engine handy, all carbed engine have had Thunderbolt ignition systems since the mid 80's.
udm328is
SN is 0D712714, as far as the check list I was speaking of is the one for troubleshooting engine starting system and did all those checks and everything checked out
Don S
The starting system has nothing to do with spark, only making the starter turn the engine over. You should have a Thunderbolt IV system, try this check list for spark problems.
Click on the picture 3 times for full size.
udm328is
Thanks Don,
I will try this out.
