I have a 83 Johnson 70HP 3 cylinder. I've done a spark check and it seems #1 is getting good spark, #2 is getting none or not enough and #3 is getting okay spark. With the engine running pulling the lead to #1 causes the engine to stall, pulling #2 does nothing and pulling #3 causes a slight drop in RPM. Was wondering if anyone could tell me what the problem might be. The engine idles fine but when you put it into gear it stalls, which to me makes sense if it is not running on all cylinders.<br />Thanks in advance
<br />Martin
