Re: No spark - MerCruiser 5.7 lt '86 Alpha 1
I put the multi-meter on both the positive and negative sides of the coil but there are no volts at all. The lanyard switch was on. I have a Quicksilver 3000 shifter and it has a run and off switch only.
Put the red meter test lead on the + terminal of the coil, and the black test lead on a good engine ground, NOT the - terminal of the coil.
Does the engine still crank over ok? If so, there are no fuses causing the problem.
If you have no power to the purple wire on your coil with the key in the run position, you need to check voltage at the following places as shown in the picture below. (just a generic ignition system picture, not exact to yours)
This is done with the red test lead on the terminal being tested, and the black test lead on a good ground.
If the engine cranks over ok, check terminal 5 on the ignition switch to verify you have a good ground for your meter. Then check 6, 7, 8, and 9. to find out where the voltage is missing.
