Re: No spark No.1 1970 Evin. 18hp
No switchbox. What he has are two modules that replace the ignition points, likely MagnaTune as they are the most common kit.
Yep that is the set up. I think the name of the modules start with an "A" but not sure I am not in front of it now.
1. swaped the leads from each coil to each module. Still no spark on number 1.
2. swaped the coils for each cylinder. Still no spark on number 1.
Thus eliminated coils and the electriconic modules as a problem.
I ordered a high lead for the spark plug wire with a new clip. Although I did show continuity when checking the wire with an ohm meter.
Has to be a grounding problem or the coil for the number one cylinder is not getting energized by the flywheel. If the cylinder coil for cylinder number two works wouldnt that mean the magnets (which are the same are they not) work for the coil on number one cylinder.
I am still thinking a grounding problem with the the timing base or the wires leads from it to the modules. I have not swaped out the bracket that the coil connects to which would have been the points if they were installed.
Keep the ideas coming people we will work this out.
