No spark on 1 cylinder
JDP
OK I went out this morning and checked the spark on all cylinders. I was starting to think that maybe my no power problem was possible the reeds. But I figured I better check the spark first. Well I have spark on all but the bottom cylinder. I swapped the red and orange wires coming from the module to the coil and I got spark. Now is there anyway to test the module to see if it is truely bad? Also would only havig 3 cylinders firing cause that much of a power loss? Also anybody know where I could find a good used module?
Thanks in advance
zimmer62
Re: No spark on 1 cylinder
I don't know where to find what your looking for, but as a suggestion you might want to post more info about your engine, and or ignition system so people might be able to help you faster.
Kajun37
swap modules and see if you get it then....if it works you got a bad one....you can find good used ones on ebay ..do a search for "force outboard"..there is a guy on ebay that sell brand new prestolite power packs if thats what you need....post your model and serial #'s
