no spark on 85 hp force 1986 bayliner capri
waverider7
boat ran great just had a problem with lower unit.set for 5 years now i am trying to get it going. no spark on any cylinder. need help. tried to look under flywheel to see if magnet came lose. but the threads pulled out of fly wheel. heli coiled the hole and heli coil pulled out.. need help with getting flywheel off and my no spark issue.
any help would be appreciated.
johnny
jerryjerry05
Re: no spark on 85 hp force 1986 bayliner capri
Use a BIG 3 jaw puller.After you install it put nut back on for a few threads.
But have someone turn the motor over while you look at the magnet.
You can see if it's spinning and the magnet's not moving.Might not need to remove the flywheel.
Check the kill switch first.J
waverider7
where is the kill switch is it the same as the landyard switch. should the ignition switch send a ground though the white wire to cd unit.
waverider7
well i found that the ignition switch was grounding the white kill wires to the cd units disconnected and have spark now still wont start though. please help
