No Spark on One Plug wire
BigDogz
Its a force 50 model # 507X9b getting spark from only one plug, both plugs are good if I switch. any suggestions or solutions.<br /><br /> Thanks,<br /> Bigz
roscoe
Re: No Spark on One Plug wire
Swap the 2 coils and see if the probel follows to the other plug.<br /><br />Hopefully it is the coil, and not the cd module ($$$).
BigDogz
What would be the difference in price from one to the other? (coil vs cd module)<br />And thanks for your reply Roscoe
peteypug
Bigz...<br />I replaced my cd last month....134.00$<br />Coils run anywere from 30-45.00$ depending were you get them from.<br />I would suggest ebasicpower.com<br />Or your local napa store.<br />Either way you will have to order the parts.<br />jas...petey
Docdoc
Check your wires coming from the stator to the coil packs. You may have a loose one. Or one that is grounding out
