Hello everyone. I have a 1970 Evinrude Sportwin 9.5 that ran great for the last two seasons. At the end of last season it was running fine one day and the next I had trouble starting it and when it did run it had very little power. I changed the plugs which didn't work and when I pulled the plugs, one was fouled and the other looked fine. I tested for spark on both plugs and the plug for the top cylinder has no spark. I'm assumming a bad coil or wire. What should be my next step? 'How easy is it to change a coil in this motor? I know nothing about pulling the flywheel to access the coils. Any way of determining if it is in fact a bad coil?
