Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
91 60hp Mercury ,New Power Pack , New stator , New trigger,still no spark,quistion? Could the rectifier or starter cylinoid be the Cause and if so how can I check them.?
Hello<br /> your about down to a grounded black/yellow kill wire or bad flywheel magnets.<br />was the stator replaced with a new one or a new to that motor new one? have you done resistance tests and voltage output test on the trigger,stator and primary coil voltage at ignition coil posts.<br /> do all the basics and I bet you will find the problem <br /> good luck and keep posting
WE PUT A BRAND NEW POWER PACK AND STATOR ON IT AND IT STARTED UP AND RAN FOR ONE DAY AND NO SPARK AGAIN , PUT NEW TRIGGER ON BUT IT STILL NO SPARK . SO WE TOOK OF THE BLACK/YELLOW KILL WIRE STILL NO SPARK WE ALSO USED A BYPASS QIUCK SILVER SHIFT BOX TO CHECK IT.ALSO USED JUMPER WIRE TO STARTER. NO VOLTAGE GOING TO COILS. THANKS!!!
hello<br /> your back to square one. what color stator did you put on? if it was black take it back and get a refund. only use the red stator kits. start all your ign trouble shooting over again. I think you have some poor mexican parts in your motor.most of the electronics are either made or assembled in mexico. thank you bubba bush SR. any way start from the front of section 2 I think and go from there<br />Good luck and keep us posted
