No spark until end of cranking
Atum
Hey all,
New to the site. I have a 1977 Evinrude 35hp model 35753c electric start. The motor was my Dads and it has been sitting for awhile. I pulled flywheel. lightly cleaned and changed coils, they were rusted and separated. I tried pull starting and I got a spark when the flywheel stopped turning. Any thoughts on what would cause that ? Haven't changed power pack yet, but, that's what i'm thinking. Thank You
saltchuckmatt
Hey all,
Disable the kill button just to rule that out. Is the timer plate wobbly?
Atum
Plate feels good. Another question, trying to bypass switch also. I tied the white wire, red black stripe, and purple white stripe together. I left out the black and black and yellow stripe. Is this correct? No kill button, pre kill switch. Simplex controls. Think thats the name.
saltchuckmatt
I saw the old controls but your key switch grounds out the motor to kill it. Came with the black plug I presume?
This part failed this weekend on me creating havoc...that's why I asked about the timer plate. With the motor off and you rock the flywheel back and forth, observe the timer plate.
The plastic ring cracks and breaks up.
Atum
Yes black plug. I will check plate in a few days and report back.
Atum
I can wiggle the plate up and down, not side to side, other than what its supose to. I dont have the flywheel torqued down but its close, and tight. I may have to rewire this motor, as it has set for years.
The timer plate will move up and down not back and forth
saltchuckmatt
What mine was doing, is when rotating the flywheel you could see the timer plate bouncing around. Pull the 6 or so Phillips head screws on the top of the timer plate and inspect/clean/re-lube the plastic bearing. Mine had missing pieces.
Atum
Plate looks good . Do you know which wires to tie together to bypass the switch? And how do disable the kill switch? Sorry, Im new to outboards.
Atum
Ok sent that recent reply to early, now I'm getting fire on the bottom coil only.
Atum
Yeah, your pack is bad then
Just received my powerpack yesterday, was lost by USPS. My wife was in a car accident Sept. 2. She is fine. Car is totaled. I've been dealing with that, so I haven't had time to fool with the motor. Will repot back soon
Thank You
saltchuckmatt
Thank You
Understood, get your affairs in order.
