no spark-wiring diagram 1992 Evinrude 60 HP
jimmytee
Anybody know the color codes on the wiring for a 1992 E60 VRO, especially the kill switch? Not getting any spark, and have reason to suspect the kill switch. Anyway to bypass it from the terminal strip in the engine?
steelespike
Re: no spark-wiring diagram 1992 Evinrude 60 HP
Kill switch color is Black w yellow stripe.Two M terminals
on switch one connected to black wire(ground) the other connected to black w yellow stripe when the switch is off these 2 are connected together.There is probably a terminal strip with black yellow wire, disconnect black yellow.
ezeke
The black and yellow wire goes to the power pack from the control harness. There may be a plug, but the wire is not usually found on any terminal block.
jimmytee
well, that wasn't it. Still no spark. Any suggestions what to try next?
