My 1989 Mercury Classic 50 outboard has an intermittent problem with spark. I brought it to my local repair marina and they could not duplicate the problem. They put it on their own control system and, at first, it wouldn't start. He then buttoned everything back up, and it worked. He replaced the stator, as some of the wires were burned and he indicated that there was not charging voltage. So that problem is fixed, and supposedly, it fires right up. That was fine the next 2 times I took it out, then.... same problem. No spark. It just cranks, and cranks. I have checked all of the connections, and cleaned the plugs. PLENTY of fuel is pumping during crank. Choke on or off, still just cranks with no spark.
Any suggestions?
Any suggestions?
