no spark with plugs in
rob 135
have 1973 Johnson 135 .replaced bad stator and power pack have fire on all cylinders with plugs out ... install 1 plug without plug wire hooked to plug , just screwed in either bank and will only fire on 1 cyl. put all plugs in and will only fire on one cylinder . how can just screwing plug in stop fire ??????
boobie
Re: no spark with plugs in
Is the mtr spinning over fast enough ?? It has to spin 250-300 rpm for the ignition system to work.
rob 135
yes spinning fast enough .. has new power pack and stator ... read some where could be trigger gap needs adjusting .. I got new plugs to try today thinking maybe shorted ??? im stumped
boobie
You're on the right track with the trigger gap. OMC used to make a tool for it but I can't find the #. Maybe somebody else will chime in.
boobie
You could also have a bad timer base.
rob 135
Adjusted timing triggers . Have spark on all cylinders . Fired up for few seconds . Now has fire but won't start again . How does triggers stop fire with plugs in ??
