oldboat1
- Joined
- Apr 3, 2002
- 9,612
I'm trying to get a 9.9 autoelectric running (mod. 95HA) -- getting no spark. The coils look OK, as do the points (which I regapped just to be sure). The condenser wires had some wire showing where the flywheel had apparently come in contact -- thought that might be the problem, and tucked them out of the way. I still have no spark, though.<br /><br />I don't know how to test coils. I sort of figured I would find that the cases were cracked as on some OMCs I've worked on, but they look fine.<br /><br />To further confuse issues, I pulled the flywheel on a 6hp powerhead I have for parts -- same magneto, and also no spark. I found the same thing (coils and points look fine). Again, there was some abrasion of the condenser wire. <br /><br />What is the likely problem? I don't have known good coils to swap out, and these are apparently a little hard to find. Would a bad condenser cause loss of spark? (or a bad condenser wire? I checked for continuity, and it checked out OK.) Is the problem the coils, even though they look fine (actually, all four of them)?<br /><br /> Thanks in advance for any ideas.<br /><br /> Curt
