Water Plug
- Joined
- Jul 6, 2006
- 23
Hey Dave sounds like you found a jem in the rough! Kind of odd that both died, before you spend your hard earned money on parts you might not need check on the simple things first.
Have you made sure the wiring is correct to the ignition switch, check on the condition of the plug wires, lose wires, dry rotted wires, wire connections and so on.
It's a good place to start looking before you start spending.
If you look for the complex,
you will always miss the simple.
Brian
Brian
