No spark?
2mate
Hi guys,
My 1998 Evinrude 25 isnt sparking. There is a crack in the Powerpack/Cdi unit as pictured. The coil terminals have quite abit of rust on them also. Could this be the problem?
mars bar
Re: No spark?
Yup, Cracks allow moister to enter grounding or shorting out the spark. $$$ BOAT...Bring Out Another Thousand.
boobie
Re: No spark?
It may not be the prob but I would replace it on G P's.
2mate
Re: No spark?
Thanks for the info guys, is there a way to test the pack before i splash out ?100?
Also the engine did fire on one occation but hasnt sparked since. Does that sound like the power pack?
boobie
Re: No spark?
If you have an OEM factory service manual, an open air gap spark tester and a peak reading volt meter or an ohmmeter with a DVA adapter you can check them out.
