No spark
I have an old 59,50hp evinrude.I have put new rotor,condencer,and points.still no spark.what else shoud I check?
Kenny Bush
Re: No spark
Dead in Water, check the coil situation......Make sure the wire to the coil is hot also. Are your points set right? check it out and let us know....Goodluck....BushCat
Re: No spark
bushcat,the boat was running just fine,I took it from the boat ramp to the house to flush the motor and it would not start.Would the coil go out that fast?
Walker
Re: No spark
First thing to check is the kill circuit. I don't know your particular motor so I can't tell you exactly how to check. I'm sure someone else will help.
Kenny Bush
Re: No spark
Deadman, that is truly wierd..... Walker may be on to something...Do you have a mercury switch(switch that kills ignition when motor is up) on that motor. I have never seen a coil go out that fast....Coils usually start going out after they heat up, due to the windings breaking down, and as the coil heats up it expands thus pulling the wirea apart. Anyway stay on it...... Goodluck....BushCat
