What engine do you have? WOT should be about 4200-4600 in that age range if it is a GM block. Always verify your tach with a shop tach. I would put money on a spun hub. Mark a line across your hub and prop nut, run it in the water, and take a look at the alignment. If the line doesn't line up any more, your hub needs replacing.
