straightleg
- Joined
- Apr 11, 2011
- 79
Had to wiggle my handle, shift in and out of forward to get the engine to fire. Everyone hear pointed me in the direction of stretched lower shift cable.
Being I was a not confident enough to do the cables and belows, took it to a shop.
They did bellows, cable, trim pucks while they had it apart per my request. $1400 ouch
Also needed an alternator for that price.
Ran perfect first time out. Started in nuetral with some gas like it should, did not stall in reverse like it was doing on ramp getting off trailer. Was Happy
Second time out, had to play with handle in and out of gear some to get it started, third time out same but a tad worse.
Hooked up last Sat to go fishing, thought I better put muffs on and warm it up first. Double check it.
Can barely shift in reverse with engine off
Wont start in Nuetral
After holding key on and wiggleing handle back and forth, engine fired.
Going into reverse there is a clanking noise, like it is not fully engauging.
Very hard to find the place with handle to get a fire, and reverse feels like something is going to break if I try to shift it with engine off
Waiting for the place to open to take it back...
ANy thoughts
Why did it go south?
Also when I pulled my top fill plug to see if they put gear oil in it was 1/4 to 3/8 below hole.
Thanks
Gerry
ANy thoughts
Thanks
Gerry
