no start cranks
peter paul
any one give me a little advice here it is 1982 mercruiser 4 cylinder had the motor running adjusting the timming ti 4 degrees, and i found out everyone say set it at 8 degrees. anyway ran and push it in the lot next day went to start wont start. i didnt get time to check it out but any quick advise where to go. dont make sense motor was running smooth before i push it in did not do anything else,
Don S
Re: no start cranks
Does the starter turn the engine?
peter paul
Re: no start cranks
yes it crank but wont start do you think i set the timming and had it running so when i turn it of and push it in the lot the timing was wrong when motor got cold im just say cause i cani figure it out.
Don S
Re: no start cranks
Do you have spark?
peter paul
Re: no start cranks
Do you have spark?
well in the afternoon i let you know cause it when im going to check it out, like i said the motor was running fine.when i adjusted the timming. i turn it off push it in the lot next day went to start no start. but i will post later if i cant fined the problem
peter paul
Re: no start cranks
well what do you think was running push in lot next day wont start
