johnzonh
- Joined
- Jun 11, 2008
- 137
Ok I am at wits end. I have the black sheep of mercs but after getting rid of a coolant leak with a riser gasket (and subsequent new head, intake, and exhaust gaskets..) couldn't get my engine to start.
did quite a few things...
rebuilt the carb during the winter (mercarb 2bbl)
had a bad starter...replaced that.
had a bad starter assist solenoid...replaced that.
needed to rule out compression issues... no problem there.
needed to rule out ignition issues...replaced coil (it failed the resistance primary test) replaced plugs, wires, condenser, etc.
wanted to make sure the coil was getting enough juice at the start..replaced the solenoid wire to coil, replaced ignition wire to rule out voltage issues to the coil.
when i realized the engine had a coolant leak, it still fired right up even with all the garbage in the oil. I didn't let it run more than a few seconds. no hydro lock. mechanically sound
ok..so after all that... this morning...the engine finally popped a few...but quit.
Could not get it to start again, added no gas.
smelled gas... which has been strong nonetheless. took off the carb... intake manifold was swimming in gas.
emptied the gas... tried again..same issue.
pulled the carb... intake full of gas... went back to my carb kit and replaced the float needle with the spring set (per instructions in many places that identified this issue)
cleaned out the carb... re set the float for the the new needle set up.
carb back on ... added NO gas, primed NONE. intake flooded again..
the carb see through tube is clear. the fuel pump is the stock mechanical, it IS pumping fine. even by hand crank of the engine. there is a filter under the pump. no separator before it. The fuel lines were inspected along with the anti siphon valve. the tank vent is clear.
I give up. I am at the end of my expertise with this thing and I just don't know where to go from here. Every thing I have done so far is to spec.
