jjacobs007
- Joined
- Mar 10, 2009
- 1,257
these are pics of 4 before shots and one near complete post more if needed.
This was the response I received comparing rotary with and with out NFB
Regular steering is -- well -- regular steering. If you let go of the wheel while underway the steering may move by itself one way or the other due to to engine torque. You therefore need to apply some steering effort to keep that from happening. The higher the HP the more of an issue this is. NFB steering systems have a locking clutch in the system that prevents the wheel from turning. Just a slight pressure by the operator releases the clutch and steering is normal. It is a great system but does take a little getting used to. You will probably complain that steering is hard to make minor corrections. Fact is, you are over steering so set your direction and unless wind or water conditions dictate, you shouldn't need to make those tiny and frequent small wheel movements.
I'm just guessing but it may have something do with the locking clutch
Are you trimmed out properly? Mine is a bear to steer on holeshot until I trim out. Once it hits the sweet spot, I can turn it with one finger (200 HP, cable steering).
No. Those brackets are only for motors without a tilt tube. You don't need that.
this sounds like your on to something here,i am in the process of hooking up my switch at helm to control tilt n trim and then ill try to find that sweet spot.do you think a trim tab if off a larger mtr was installed it would affect it.
I don't think the trim tab will help with steering effort - that's more to counter act a pull to one side. Definitely get the tnt hooked back up and play with it on the water. I bet a donut you will find that once on plane and trimmed out (up) properly, it will steer much easier.
I am having the same problem, very easy to turn either way sitting, but at speed it takes alot of effort, I have tnt and still makes no difference on the steering. I wonder if the motor could be too low??
I see you're using a used engine. You didn't say if the steering system is new. If not, sometimes the cables will bind in need of lubrication. Also, the rod on the front of the motor can gum up due to weathering/water--needing cleaned out with a wire brush and relubricated.
It really sounds as if an adjustment of the steering trim is needed. I suspect there's a plug on the top of the lower unit that can be popped out, and probably an allen head bolt needs loosened. If it's difficult to turn the steering wheel to the right, you move the tab a little to the right and tighten it up. Then, run the boat. When effort to turn the boat is the same side to side, you've got it right.[/QUOTE
newer teleflex system bought used on e bay,the allen wrench ththing im confused mine doesnt have that i think.
what kind of boat and mtr you got?
I have an '84 17' crestliner with a 90hp johnson with the same set up as yours. Turns very easy until you get going...
my bet is that the trim tab needs adjusted
How tight are the bends in the steering cable?
