new to forum don't know if this is new thread or not.
I have a 25 hp 4 stroke engine that i bought in 2000 which ran well till my state mass switched to 10%ethanol last year. AT full throttle my engine would cut out and the only way i could keep it running was to pump the bulb. I did all the research and replaced all the lines filters new fuel pump added a fuel water
separator even changed the tank. I also rebuilt the carb. on my second tank of gas this year i have the same old problems.
I called Yamaha customer relations in Georgia 866-727-2200 and talked to a tech and he said that i was out of warranty acknowledge there is a problem but its not Yamaha's they blame it on the fuel saying that you don't get 10% ethanol at the pump it actually is much higher and is not regulated since Yamaha does not make the fuel it is not their fault. if i was still under warranty they would give ma a new carb. but once your out of warranty they do not want to here from you.
I mentioned that there is a known defect and that they still sell the engine in mass now how can that be considered good customer service all he said is your out of warranty. if your thinking abour buying a yamaha think againl
mitir
mitir
