no t-stat in cylinder
jjdluz
i replaced water pump of my 92 yamaha 200 outboard because over heating,and i loss 4 bolts checking the t-stat,find out there is none t-stat in it on both cylinder,is that ok,i run the boat wot on and off for 2 hours ,not over heating,i belive i fixed it,but no t-stat is ok ?any good advices,thanks.
cebu
Re: no t-stat in cylinder
well the thermerstates job is to restrict water flow when the engine is cold ,then open up when it gets warm, if your in a cold climate running the engine ,theres the possibility of the engine running below correct temperature ,but they are not to expensive and easy to install
jjdluz
what is correct temp running 92 yamaha 200 outboard,and i take my boat out mostly temp around 55 and above,and it get warm up about 70,and the motor it is about 100,is that ok without t-stat?or can i just put one in at one cylinder?
rodbolt
normal operating temp is in the 140-150*F range, the thermostats are also part of the pressure control system, they need to be there.
