duped
- Joined
- Aug 26, 2009
- 307
As some may remember, I posted a thread Friday about replacing intake gaskets trying to track down a problem of water in oil. It seemed pretty clear to me that one was blown and heavily corroded. I spent 6 hours just cleaning the gasket surfaces and prepping. I went so far as use fine grit stones to remove all corrosion and surface defects on heads and manifold. Everything was a machine surface when done. I used marine gaskets and aviation glue on both sides to ensure a seal. Torqued in the proper pattern to 30ft lbs. Also inspected the intake manifold and lifter valley for cracks and found none, supporting my theory that this block CAN'T be cracked. Water ingestion issues JUST started in the middle of summer and have been draining and winterizing properly since 2009 when I bought it. I ran diesel and the oil and then changed it again after the job was done.
In short, I'm 100% certain I did it properly, thanks to the help of folks here.
Anyways, I got it out on the water yesterday, and I am still getting water in the oil, although it seems like less. Approx 1 quart in 6 hrs run time, some trolling, some cruising.
When I did the gaskets, I found out it has no thermostat installed. What reason, i dont know. It did need an impeller when i bought it, so that may be it. I ordered one but until it arrives im sitting here speculating and looking back... recalling all the steam that comes from the valve cover vent tubes during running, especially this year with the water being colder. Now I'm to understand that this vapor will usually burn off once the motor is up to temp, but it never gets there without the TSTAT...so could this be the source of my oil contamination? There's an awful lot of moisture/cheese under the valve covers which could support that theory. Just so strange. Thoughts?
