bart98stang
- Joined
- Mar 6, 2011
- 104
Greetings! Because if the information from many of you I was able to fix my overheating problem by rebuilding my water pump and poppet valve. Thank you! However, there are no thermostats. I guess the previous owner removed them to hide the overheating problem. Without the stats the engine so far has not reached a temp above 145 degrees. Can this effect the performance of the engine? Thank you very much.
