Re: no trim at higher speeds
Are you all the way trimmed, after a certain RPM it will trim but not tilt. Try trimming all the way in, then run the engine at high speed, & trim out, to see if it moves, if it does you may have reached the trim limit after that is tilt. Good luck, Joe
