I just acquired a 1986 35hp force the white one. I put it on my boat, and stuck it in a barrel and started it up. Nothing was coming out. I ran it until I could no longer do the 3 second touch dealio. <br /><br />So, I figured no problem the motor has been sitting for a couple of years so it needs a impeller. So I take the lower unit off and take out the impeller, and it looks brand new, and the fins stuck straight out. It is still pliable and springs back out. So I am thinking another impeller is not going to fix this problem. I look and it does not have any water hoses inside the cowling. So, I am guessing that all of the water goes out the exhaust, but some should be spraying out of the two holes half way up the leg, but doesn't.<br /><br />It still has great compression, and I want to keep it that way, but don't know why it isn't pumping water. I looked down into the lower unit, and the water pickup is all clear. The tube in the top of the water pump is nice and tight. Where the two tubes connect together looks good. The inside of the water pump where the impeller rides looks good. The plate looks good. So I am wondering what it could be. It is a fresh water motor. I don't see a thermostat anywhere. <br /><br />Anybody have any ideas? I do see a allen key plug at the top of the head, but that's about it. So I don't know where I could back flush it from. Maybe from the allen plug on top of the head. What do you think? What am I missing? Any ideas?
