oneathefaintest
- Joined
- May 9, 2009
- 21
Hey guys we just got a 2006 tritoon pontoon with a Honda bf225 hoarse motor. Hooked it up to earmuffs to flush it out......but theres no water exhaust anywhere, when you shut it off warm water seeps out little holes on the lower unit but thats it? Also the water pressure gauge on the console isn't registering. When you put it in gear you hear a clanking noise but it goes away if you throttle it up at all, other than that the engine only has 8hrs on it sould like its running good. It was in a huricane 8 mnths ago, if something hit the prop could it cause this problem. Any ideas would be much appreciated, im thinking water pump but I dont know a lot about outboard engines. I dont want to run it anymore until its fixed if water isn't getting to the engine.
