jdavis7873
- Joined
- Feb 15, 2009
- 2
I am at the end of my very short mechanical aptitude with my motor. Last time I took it out, there wasn't any water flowing out of the pee hole. no big deal, I assumed it to be the impeller. took it off, inspected it and everything was in good shape. Just to be sure, I replaced it anyway. It didn't help.
With some good advice from a local mechanic he told me to check to make sure the thermostat wasn't froze up. Much to my surprise, it wasn't froze up, THERE WAS NOT THERMOSTAT IN THERE. I know this isn't great, but it also isn't the end of the world. I had a car that we kept the thermostat out of for a while and it didn't hurt anything, but I will get one for it. While I had it apart though, I tried to run both water and compressed air into where the water flows. There was very little(basically none of either coming out where the fuel pump/pee hose is. Thinking there may be a block in the line, I took each of the lines from the pump off and neither were blocked, I also blew threw the fuel pump and there wasn't anything there.
I know there has to be something blocking this, but I have no idea where now. When I did put a little air pressure in there and sealed up everything else real good, I noticed a little water coming out the spark plug seat in my top spark plug...
This got me to thinking bad thoughts... Would this likely be blown head gasket or maybe even a cracked head? Upon further inspection, I noticed that the threads were starting to rust.
Is it time to put this motor out of it's misery, and sink for a crappie brushpile?
