No water from exhaust ports on Merc 9.9
WallyMaster
My 1987 mercury 9.9 has a good strong stream out the peehole, and the water coming out is warm (not hot) to the touch. But there is no water coming out of the exhaust relief holes on the upper motor leg. SHOULD there be water coming out the exhaust relief holes on this particular model?? Or does ALL water exit from the peehole?? (I removed thermostat and still no water from exhaust ports). If water is supposed to come from exhaust ports, then what might be the possible problem here? There have been no indications of overheating. Thanks.
Texasmark
Re: No water from exhaust ports on Merc 9.9
Depends on the plumbing, engine rpm's and back pressure on lower unit (submerged and boat stopped type thing). The exhaust relief ports are just that and don't necessarily contain water, but could and as stated depends on the above as to how much.
Water should be draining out the prop when on muffs, along with your pee stream.
I used to ski behind a 125 Johnny and there was a nice solid casual flow of water out the ports at skiing speeds. At idle, boat at rest in the water, there might be a slight mist or sputter from time to time.
I don't know about while skiing as I haven't done that for a long time, but at rest, all my past and my current Merc 90 sputter somewhat.
Whether or not your pee stream tells you that all is ok depends on where it is plumbed out and whether or not you have a thermostat and a popoff valve (on larger engines). If it is plumbed off the exhaust manifold water jacket cover (side of the block usually on the port side for inline engines) it just says that the water pump is pumping. If it is plumbed off the head water jacket (where the spark plugs are) it probably is down wind of your stat and if peeing says that the pump is pumping and your stat is opening..............but on that rig, the stat has to open first before you get pee. Sometimes waiting for the initial opening to know you are good to go seems like an eternity.
Mark
WallyMaster
Thanks, Mark. That info is helpful. The motor's behavior, then, seems to be normal, especially since there has been no overheating.
79Glastron
I have a late 70's 7.5 which I think is almost the same motor. I never had water come out of the exhaust ports. I only had water exit the "pee hole" and the prop hub.
