charliegiggles
- Joined
- Oct 19, 2006
- 50
Hi,
I have a 1979 70HP Mercury. I'm having issues lining up the copper water tube with the water intake hole. Is there some trick to lining it up as I tried running the motor and there is no water coming out of the pee hole so I shut it down after about 20 seconds.
I'm not sure if I'm in or beside the hole. I really wish there was a guide. I tried putting the copper water pipe parallel to the drive shaft with the same spacing as can be seen between the crankshaft "with a flashlight" and the water intake hole in the upper casing.
I took it apart and put it back together 3 times still no luck. Also was able to blow air through the head to make sure there was no blockage. I also checked the impeller to make sure it turns with the drivesaft so I know the key is in place.
I'm using mufflers.
Thanks.
I'm using mufflers.
Thanks.
