Fishinforfacts
- Joined
- Sep 19, 2020
- 2
I have lost the water from the tell tale. I do not get any water out when I have a hose hooked through the flush port or when it is in the water. When I was out last week I had no water even when running, but never overheated. This engine does not have a hose that I can find that goes to the tell tale, so I can find a way to clear a blockage if there is one. The tell tale is a rubber flanged piece that has a tapered end that fist into the drive shaft housing. Just below the tell tale is a second drilled tell tale as well, If I hold a hose nozzle to the tell tale to back see if I can clear any blockage and also hold a finger over the drilled hole, water then comes out of the prop so no apparent blockage. The hole for the tall tale is located in the water outlet side at the rear of the shaft tube, so there is no easy access. I have also just change the impeller on the engine as well and the was no damage to the impeller, but the vanes did have some set to them. Anybody familiar with this engine and have any suggestions.
