Tanksmydog
- Joined
- Jul 8, 2008
- 41
I have a 1973 Merc 500 and recently brought it out of storage, I fired it up and with the help of a little starting fluid it was running good. BUT when I tried to went to make sure the prop was moving good, it would not move. It is not seized up or at least I dont think it is cause I can move it with my hand easily. I shut it down to check out the cables and when I started it up there was no water stream, before it was a strong water stream, now nothing. Shutting it down quickly I could find nothing obstructing the outlet or the hose leading to it. Whats going on? I have spent a lot of money rebuilding this outboard so far but have done nothing to the lower unit...is it the impeller or the water pump? Is it an easy fix? Cheap? I am hoping to do this myself as I have the Seloc Manual and am pretty good with my hands.
