I heard this whistling sound coming from the control box while running down the lake. Very soft and steady. I turned off the engine, 87 50 hp Evenrude. Checked a couple of things out and found everything to be ok. Started up and never heard it again. Same thing happened once last year. New water pump and t-stat.
Any Ideas?
How hard should should the primer bulb get? I thought
I was having problems with the old one because from time to time the motor would bog down when I took off. Same problem with new hose.
Any Ideas?
Thanks for the help in advance.
Any Ideas?
Any Ideas?
