noise from lower leg of tohatsu 60 c
david12
As i flush my moter with a set of ear muffs i put it into forward gear at just above idle there is a chattery noise but when i place it back to neutral it is not there.
pvanv
Re: noise from lower leg of tohatsu 60 c
Probably just gear lash, since the prop is not under load. A skilled tech with the right apparatus and dial indicators can measure the backlash if you are so inclined.
david12
Thanks heaps Pvanv i will talk to my technician about it,i have heard talk about the clutch dog if worn could cause the noise also.
