ok, i posted a thread a while back about getting my alpha one gen II sterndrive back on after replacing the gimbal bearing. I ended up buying a alignment tool and managed to get it on. when i started the motor the bearing noise was gone but there is a knocking noise coming from the outdrive when the trim is up. it fades out as you lower it and when it is in normal crusing position it sounds fine. it also makes noise when you turn the wheel to either side. there was no knock before i replaced the bearing and the u-joints felt tight when i had it out. do you think its the u-joints? any advice is appriciated!!
