noise proofing
djvan
I just brought my boat out of winter storage. I have an older 4 winns i/o. <br /><br />My question is this: The motor cover is the kind with two seats next to it (one on either side) under the seats are a flap of upholstery that is attached at the top and has three snaps at the bottom. If I took some sort of foam insulation or similar and custom fit pieces in behind these "flaps" would I notice a reduction in noise? Don't know if foam would be the thing to use or not, maybe something that is flame resistant? The motor cover itself is insulated with some sort of spray on foam.<br /><br />DougV>
rybad
Re: noise proofing
Check you local boat store, or BoatUS.. they sell "sound proofing" material. It's s dense foam with a thin metallic covering. (I think its about $60 for a 3' square)<br /><br />I have a Four Winns 284 Vista, this material is under both engine hatches.
djvan
Re: noise proofing
Thanks that was quick.<br /><br />DougV>
doman
Re: noise proofing
you can alo try some silver bubble pipe insulation at home depot ..works pretty good for me on my engine cover <br /><br />Dom
xltier
Re: noise proofing
there is sound proofing with a lead barrier layer available at boat yards.hamilton marine in portland, maine is a place that carries it.
captkid
Re: noise proofing
xltier howdy, a fellow mainer :) <br /><br />hows the lakes up in Norway treatin ya
djvan
Re: noise proofing
thanks guys <br /><br /> My engine noise isn't very bad I just thought I may be able to quiet it some more, need other stuff worse at the time though.<br /><br />DougV>
