Noise when i turn the wheel all the way to the side
jarata
I was testing the boat in the driveway today when i was moving the wheel all the way to the side it made a ratteling noise.When i centered the wheel; the noise dissapered.is this common or can it be from sittintg all winter and needs to get out.
jevery
Re: Noise when i turn the wheel all the way to the side
Need more information. When you say "testing" do you mean the engine was running or not? Is your boat outboard, or I/O? Was the ratteling coming from the steering/dash area or the engine?
jarata
its an io was running the engine noise was coming from the io in the back
Gary H NC
How long has it been since the outdrive was removed and u-joints and bearing checked?<br />It should be done every year...
jarata
what kind of grease do i use
tashasdaddy
had this type problem a while back. steering linkage was hitting the exhaust y pipe on full turn either direction. made a horrible noise.
