Non-Boating Question
Panther2006
How do I make my Pic's smaller. I'm using Photobucket and when I paste the Img. into the post the pic's are huge .
Thanks
5150abf
Re: Non-Boating Question
You need to sign in first, I can get ot my Photobucket from my favorites but it won't let you do anything unless you are signed in.
After you do that on the top left of every pic is an "edit" option, click that and you can resize, I normally have to go to 480.
tashasdaddy
if you have microsoft picture manager on your computer it is very easy to edit the pics, and resize them
skargo
Banned
It's easy as pie to use MS Paint as well.
1. Click Start, Programs, Accessories, then Paint. to start Microsoft Paint.
First Method
1. Open the image file you wish to edit.
2. Click the Image Menu at the top and select Stretch/Skew Image.
3. Choose a percentage figure to resize the image. To avoid distortion, choose the same percentage for the horizontal and vertical stretch.
4. Click OK.
5. Once you have the desired size, click File, then Save or click Save As... to prevent overwriting the original image.
Second Method
1. Enable Num Lock by pressing the Num Lock button on your keyboard.
2. Select the entire image.
3. Hold down Ctrl and press the - or + button on your number pad to resize the image. The number pad is a square arrangement of numbers and symbols on your keyboard, that can only be enabled with the Num Lock.
kenmyfam
My Sony cybershot has an option to take each photo as a high quality image and an e-mailable size at the same time. If you have enough on your memory card it is a good option. I use it virtually all the time as when I am away on business trips to review and buy off tooling I can send photos back to the office easily for reference.
Panther2006
Thanks Guys,I think i might have figured it out but this was much easier
thank again
