Non-OEM trim relay
tgell001
My trim was acting funny this Sunday. Got to the ramp and it wouldn't trim up. It go down, but not up. I am able to get one instance of up if I wack the relay with a wrench. OK so easy right? Old sticking relay, replace move on. Except this is not like any of the parts in seeing that came with either motor that has been in this boat. 1996 cobalt 253, currently has an 8.1 gxi-d with a DP-S. Factory motor was 7.4 of some kind, all anecdotal from the previous owner, I think it was VP.
What is this? Where do a get another or suitable replacement. Rewiring isn't an issue, it's a relay, but everything I'm finding is OEM for something and not universal
https://photos.app.goo.gl/TAdw1mufPCxMBwhMA
There was a piece of duct tape covering these contacts.
https://photos.app.goo.gl/7NtJbTA63KtHuof49
Some part of a number
https://photos.app.goo.gl/i112kgoGofkG2qmn7
tgell001
I don't see why I couldn't cut the connector off this and make it work. Seems like its just up, down, and ground. Then one for one with the terminal lugs
Jade Outboard Power Trim Tilt Relay Assembly For Yamaha 61A-81950-01-00 https://www.amazon.com/dp/B074ZN2XN3/ref=cm_sw_r_cp_apa_AWiHBbQVASW44
And this looks more like the factory Volvo design and a ton cheaper
DB Electrical TRM9200 New Wiring Harness Converts 3 Wire Tilt Trim Motor To 2 Wire 30 Amp Fuse 2 Relays 9807-100 47-35-9003 28-9807-100 https://www.amazon.com/dp/B019FNEA1W/ref=cm_sw_r_cp_apa_AXiHBbDS3Z660
