Re: non seperating grease for lu
The reason for not using Quicksilver is it is not fully compatable with some of the old motors (like my late 40s and early 50s OMC kickers). I think it has sulphur or something that slowly eats the yellow metals. I ran out of my supply of GL4 and can't find it locally so I broke the rule a yr ago and used modern oil. o telling how much life it is taking off the parts. I also used regular hypoid in a 1965 75hp OMC w/electric lower unit that speced type c. Had no problem in 2-3 yrs of running...but I didn't care about the motor either.
bp
Well sir for you and all that pull up this thread, since today was a do nothing day for me and it was cold and damp, I decided to stay out of the weather and do some internet browsing pulling up some MSDS sheets on gear lube: GL1, GL5, and Mercury High Performance Gear Lube.
Manual transmissions in cars, trucks, jeeps, (old) farm tractors, and who knows what else, use bronze bushings inserted in the housing to allow the shafts upon which the gears are mounted to rotate in the transmission. The gears are straight toothed and mesh with a straight toothed mate. They drive each other on parallel shafts, hence no end play forces that tend to try to drive the gear to one perpendicular extreme from the line of thrust or the other. Consequently they are inherently quiet with linear cuts.
Differentials on the other hand have high end loading pressures and to keep them quiet they are helical cut [cut on a helix (hyperbola)....radius, curved] and require a Hypoid gear oil to keep them running.....Hypoid vs Mineral Oil contains high pressure additives including Sulphur to keep the metal from touching metal in high thrust applications especially where you are trying to transmit torque at a 90 degree angle.
There is enough data available from use over the years to indicate that sulphur and yellow metals (brass, bronze, copper, and some aluminums) are eaten away (deteriorate) in a sulphur mix environment.
So mfgrs, of the above equipment specify GL-1 pure mineral oil for trannys and a Hypoid oil for differentials, like GL-5, GL-5 containing the additive Sulphur.
In the case of the Mercury High Performance GearLube, the container clearly states that it is for Mercury, Mariner, and Force Lower units in IO and OB applications. Does not say that it is for any and all engines including 50 year old OMC's with bronze bushings rather than SS ball bearings that Merc products use.
So, I will still use my Merc High Performance Gear Lube in my palsy triple 90 and not worry.
So much for that.
Mark
