SOLVED: NONE of my LED trailer lights work?
it was a bad ground... of course...
long version: it was a 100% bad ground in fact. the ground wire in the trailer harness is attached to the trailer with a ring terminal and a self-tapping screw. the guy who built the trailer, [and restored the boat] was super detail oriented. he had soldered and shrink-wrapped every connection. well he hadn't shrink wrapped the ring terminal where it attached to the trailer, perhaps because if it grounded against the trailer, so what? anyway, the soldered area was well penetrated... and therefore, brittle. the wire broke off completely in a brittle fracture, right where it enters the ring terminal. this was a case where conscientiousness was misapplied, i guess. then again, maybe i snapped it off myself by carelessly swinging a safety chain into it?
anyhow, i crimped on a new ring terminal, without solder this time, [my typical shoddy workmanship], and it all works great now.
-peter
