elcochino6
- Joined
- May 5, 2006
- 2
Hi everyone,<br /><br />I was reading this board and I found a lot of good information, however I still had a few questions that I was hoping someone could answer.<br /><br />I have a larson 2005 SEI 180 SKI I/O, and was looking to put a depth finder on, but I need more information.<br /><br />1) Can you use a transom mount on an inboard engine without too much turbulent interference?<br /><br />2) Can you use a transom mount transducer as a shoot thru hull transducer, or do you have to buy the seperate one?<br /><br />3) My boat has a Delta VEC hull, will a shoot thru hull transducer work on this type of hull?<br /><br />4) Does a shoot thru hull mount have to be in water, such as in the bilge, or can it be dry?<br /><br /><br />Thanks in advance, I look forward to all you input. - Erick
