Ofc Noobie
- Joined
- Mar 20, 2009
- 22
Well, this post may be a little long, so bear with me.
I just bought my first boat (an 85 Chris Craft 168 Scorpion), and took it out today. I got to the completely empty ramp, prep'd the boat away from the loading lanes (even remembered the plug), and backed her down the ramp. Everything going well so far. When I backed down the ramp though, my breaks were groaning...not really grinding, and I didn't feel a any slip. Is this normal, or should I have my truck given a once over? I got the boat in the water fine, and pulled the truck/trailer out. Outside of some nerves...so far so good.
I had some trouble getting it started, but after reading some more forums, I think I just didn't pump the throttle enough before I started. Now here is where the problems started. I pulled away from the dock, no problem. Once I got out though, I realized the water level was still fairly low, and there was alot of grass. I tried to maneuver around it, but there wasn't alot of options. Several times, I scraped on the bottom, and had to put the outdrive all the way up to keep moving (never over idle speed though). I kicked up alot of mud in the process, and several times I had a heck of a shacking in the wheel. When I trailered the boat, there was a lot of grass around the outdrive...did I do any damage to my boat? It didn't look like I chewed up the prop or anything.
And one last question...how much water should come out of the plug. When I took the plug out for the drive home, there was only a slight trickle. However, after parking the boat, and cranking the jack up all the way, I got a steady stream coming out. Am I taking on water, or is this normal?
Sorry this has turned into a bit of a novel, but any help/opinions would be GREATLY appriciated!
