normal choke function 73Johnson135
SCO
Joe, Dhadley, Clanton, others that know<br />Do ya'll notice some choke flapper opening because of the suction airflow forcing them open slightly when cranking as a normal condition on these v4's?
Dhadley
Re: normal choke function 73Johnson135
Nope. As stated in one of your other threads, closed is closed. Lots of things may keep them from sealing completely - gaskets on the silencer base slightly in the way, choke solenoid location allowing plunger to bottom out, weak or distorted spring and so on.
