Normal idle rpm for GM 305.
Re: Normal idle rpm for GM 305.
Ayuh,.... Pretty much All of our boat motors idle at 650/ 700 rpms, in gear, in the water,....
TampaBoater
Ok….I guess I have to make some adjustments to mine. I am running around 1000, but not in the water, and not in gear.
NHGuy
Set it for 700 to 725 neutral idle and it will drop to around 650 in gear.
TampaBoater
I have the repair manual, but it goes very vaguely about how to adjust the idle and the carburetor. Does anyone have any good sources to properly set the idle? I have a GM 305 with a mercarb single screw.
Fun Times
Hi there, What year is the engine model? Better yet, Do you have the engine serial number handy as well?
TampaBoater
Its an 87 mercruiser gm 305 5.0l. The serial I have to get when I get home.
go to the adults only stickies at the top of the forum and download the Mercruiser manual
